Home » Audio » General » More on time alignment. Wayne?
Re: More on time alignment. Wayne? [message #3681 is a reply to message #3679] Thu, 31 August 2006 17:47 Go to previous messageGo to previous message
The thing is, the companies that boast loudly about "time alignment" usually use it as a way to set themselves apart and I think that's disingenuous. It has always appeared like sales rhetoric to me, since the companies that make an issue of it are doing nothing different than others loudspeaker manufacturers. Their "alignment" is no better than anyone else's - It is a 1/4λ match perhaps but certainly not a true zero phase alignment. So to use the term to set themselves apart smacks of marketing mumbo-jumbo to me.
For decades, most every loudspeaker manufacturer has taken steps to match the subsystems for proper summing. Altec recommended a simple procedure to match the HF and LF drivers in the crossover region back in the 1960's and then revisited it with an application note (link below) in the 1980's. This phase matching is done for summing, to reduce the amount of destructive interference. The idea is to prevent two adjacent drivers from cancelling each other through their band of overlap, causing a spiked dip in response. A frequency response anomaly is what you'll hear if there is a problem with summing, not the time offset.
Previous Topic: akhilesh (or anyone else of course :-)
Next Topic: Still Can't Get A response On why Guitar Players know what sounds good.
Current Time: Sun Nov 15 14:17:11 CST 2026
