Home » Sponsored » Pi Speakers » Changing dimentions..
Re: Changing dimensions [message #36789 is a reply to message #36786] Thu, 06 June 2002 15:49 Go to previous messageGo to previous message
Your cabinet volume is close to that of the "stock" design, so I suspect that speakers built to these dimensions will perform well. Cabinet volume is the main thing, and if you make it the same - Your speakers will work well. Of couse, you can't make one dimension very thin in relation to the others, or standing waves will become significant. But your suggested dimensions are probably just fine.
I recommend that you move the woofer and tweeter up towards the top of the cabinet, and keep them the same distance apart from one another. I'm not as concerned with port placement, but I would leave it near the bottom of the cabinet.
Previous Topic: more ignorance of the general public...
Next Topic: Theater 4pi horn/woofer time alignment?
Current Time: Wed Oct 21 05:17:31 CDT 2026
