Home » Sponsored » Pi Speakers » Space problems
Re: Space problems [message #36766 is a reply to message #36764] Tue, 04 June 2002 12:14 Go to previous messageGo to previous message
You can always alter the dimensions of the cabinets. Internal box volume is the key point; the only relevance the cabinet dimensions have is on baffle step transformation, which is virtually a non-issue if you have your speakers against a wall anyway. So I don't think actual dimensions are any problem. You can modify the dimensions to fit your space needs.
Adam
Previous Topic: What kinds of caps and coils do most of you use for Pi xovers?
Next Topic: Another set of 4 pis - my first
Current Time: Sat Nov 07 08:26:44 CST 2026
