Home » Sponsored » Pi Speakers » Pi center channel and sub
Re: Pi center channel and sub [message #36757 is a reply to message #36756] Tue, 04 June 2002 07:19 Go to previous messageGo to previous message
If you use the right 12" woofer, there's nothing wrong with doing that.
The NHT 1259 sounds pretty good, I used to own one, but it does not play very loud.
For true subwoofer duty, I personally recommend an Adire Audio Tempest from http://www.adireaudio.com . These drivers sound excellent in a 5 cuft box, with two 4" diameter ports 12" long, and they play extremely deep. I speak from first hand experience. They also don't require a lot of power. They will keep up with your front mains at pretty much any SPL level they can throw out, except at extremely high output.
Adam
Previous Topic: question about r13 vs acoustic foam for dampening
Next Topic: Pi & Berning ZOTL
Current Time: Sun Oct 18 16:01:51 CDT 2026
