Wayne Parham Messages: 19103 Registered: January 2001
To mount the compression driver to the horn, use two 1/4"-20 bolts; You should find them in the bags that contained your cable assemblies and "π" logo. To mount the horn and the woofer to the baffle, T-nuts and screws are excellent. I prefer them for larger speakers. For smaller ones, I like to use #8 pan screws
