Home » Sponsored » Pi Speakers » Pi Speaker suggestions wanted
Re: Pi Speaker suggestions wanted [message #36614 is a reply to message #36608] Fri, 24 May 2002 13:08 Go to previous message
The Pi you refer to are the Pro's which are not as large as the Theatre or Thermionic. Sir Isaac says smaller, not as efficient or deep, one or the other. 300B should do a pretty good job with 4 Pros but I could really get into the EL-34 Triodes sold by DIYHISUPPLY of Hong Kong and represented by our good friend Kevin Haskins. www.diycable.com
EL-34's and JBL's go together like.....well.....a Fender Showman and a Stratocaster.
Also, take a look in the archives at Garlands's Theatre 4's. His design (he's an architect) seems to reduce the visual scale of them.
If you see mine you'll think that Shamu was used to push a set of Maytag's on stage at "the Price Is Right"!
Previous Topic: For Sale: Eminence Kappa/2002 2-way speakers
Next Topic: Crossover Program
Current Time: Thu Nov 19 11:51:45 CST 2026
