Home » Sponsored » Pi Speakers » Good lense for the JBL 2426H
Re: Good lense for the JBL 2426H [message #36612 is a reply to message #36611] Fri, 24 May 2002 12:53 Go to previous messageGo to previous message
Adam,
I am now using a copy of the 2370A made by P Speakers, a lot of pro shops use this brand. I do not have a 2426H on it, but it sounds great with the PSD 2002. I would love to have some JBL's though. The only difference I could see was the die seems were a little rough at the back of the throat. I used a small piece of 240 grit sandpaper to smooth it out. Now you can't tell the difference between the two. (I inspeacted them with a 2370 at the shop I bought them at) I paid about $82.00 each.
Follow the link and you will see that they are dead ringers.
Thomas
Previous Topic: question about thermionic 3 plans and bracing
Next Topic: Pi Pictures
Current Time: Sun Nov 22 22:27:07 CST 2026
