Home » Sponsored » Pi Speakers » Please design equal centerspeaker
Re: Match the flanking pair [message #36579 is a reply to message #36569] Thu, 23 May 2002 01:19 Go to previous messageGo to previous message
Erik from Holland is currently offline  Erik from Holland
Well,
That's a bad idea. Of course it'll work, but the 4 Pi's are so huge, and they're expensive for this purpose. And there not magneticly shielded. So putting the 4Pi on the television, is no option because it leaves no space for a screen coming out of the wall. Putting the television on the 4pi is no option because its not magneticly shielded and television may get troubles cause of the vibrations.
No, what I need is a center that's low and wide in front. Isn't it so that the eminence speakers have more or less the same sound. I mean, if I would use a JBL for the mains and eminence for the centers you would really have a problem.
Can you tell me about the 4 Pi's, would they need a sub added for movie use? Or do they give enough bass. Can imagine that they are design for clean, dynamic music experience. And linear effect would be lost when stuffing much bass into them.
Need to make well over thought choises, else I get disappointed. Also still thinking bout using all JBL. How much more expensive is the Theater 4Pi with 15" if using JBL? Can you give a percentage?
Don't have any idea what to do with the kappa's then.
Thanks, Erik
Previous Topic: Specs RCF L15/554K
Next Topic: Pi 4 theatre plans
Current Time: Mon Oct 26 12:59:06 CDT 2026
