Home » Sponsored » Pi Speakers » any tips on cutting baffle circles?
Re: any tips on cutting baffle circles? [message #36533 is a reply to message #36530] Mon, 20 May 2002 06:24 Go to previous messageGo to previous message
Robert Hamel is currently offline  Robert Hamel
I used the inside of the gasket as my hole pattern. You can also get a rolling ruler which is 12" long and has holes where you can pin one as the center and just use the other " correct" hole to drop a pencil through. You just spin it and you get perfect circles. Watch out for the thin blades with the Jig Saw as they will bend and you will end up with a beveled cut. Just take your time.
Previous Topic: Question for Wayne
Next Topic: Chicago Horns Summer Bash
Current Time: Fri Nov 06 03:15:09 CST 2026
