Home » Sponsored » Pi Speakers » 4Pi WIDTH, ROOM BOOST AND PORT PLACEMENT?
Re: 4Pi WIDTH, ROOM BOOST AND PORT PLACEMENT? [message #36531 is a reply to message #36517] Mon, 20 May 2002 05:51 Go to previous message
JLapaire is currently offline  JLapaire
Mike, I think your boxes and mine are similar in size, except that I made the front panel even smaller by cutting the corners off. Width is 18", 22" overall cabinet width. Speakers will stand 49 1/2" high, plus feet if any. I taped the pieces together, spread glue, then rolled the thing up into a tube. Now if the woofers would only show up!
John
Previous Topic: What would you build with these JBL drivers and horns?
Next Topic: Horn lens causing 1k bump?
Current Time: Thu Nov 19 11:22:57 CST 2026
