Home » Sponsored » Pi Speakers » Which Pi Speakers work well at low/medium volume
Re: Which Pi Speakers work well at low/medium volume [message #36523 is a reply to message #36522] Sat, 18 May 2002 19:43 Go to previous messageGo to previous message
There's not a lot of difference with respect to your amp, the amount of sound and suitability for use at low listening levels. But your room may make a difference. If you plan to use these speakers in corners or against the wall, I'd suggest using the Theater four π speakers. On the other hand, if these will be pulled away from the walls or out in the open, then you might like the Thermionic three π speakers better.
Previous Topic: Chicago Horns Summer Bash
Next Topic: 2 Pi speaker questions
Current Time: Sun Oct 18 16:03:39 CDT 2026
