Home » Sponsored » Pi Speakers » 4Pi WIDTH, ROOM BOOST AND PORT PLACEMENT?
Re: 4Pi WIDTH, ROOM BOOST AND PORT PLACEMENT? [message #36520 is a reply to message #36517] Sat, 18 May 2002 19:01 Go to previous messageGo to previous message
That will be fine, especially if you put the speakers in room corners or at least against the wall. The design works best in eighth-space or quarter-space. The difference in baffle size will change the step frequency, but placement near room boundaries counteracts baffle step.
As for the port, position makes no difference provided the port isn't obstructed. The only exception is when the port is placed in a location where there is a high pressure standing wave node. Helmholtz resonance is unaffected by port location, but the influence of internal standing waves nodes is determined by the positions of the driver and port in relation to cabinet boundaries.
Previous Topic: What would you build with these JBL drivers and horns?
Next Topic: Horn lens causing 1k bump?
Current Time: Thu Nov 19 11:23:23 CST 2026
