Home » Sponsored » Pi Speakers » 4 Pi questions
Re: 4 Pi answers (plus two Pi questions) [message #36512 is a reply to message #36511] Sat, 18 May 2002 14:07 Go to previous messageGo to previous message
Well, putting the port in the back will only require you to leave a bit of clearance between the speaker back and the wall or wahtever. I usually rear mount the ports if the woofer is reproducing higher frequencies so you don't have them eminating from the port and interfering.
They'll still eminate from the port in the back, but a lot less will get around the speaker and to your ear.
Adam
Previous Topic: LOOKING FOR A 2way Crossover
Next Topic: question about applying veneer
Current Time: Sun Oct 25 08:24:43 CDT 2026
