Home » Sponsored » Pi Speakers » 4 Pi questions
Re: 4 Pi answers [message #36510 is a reply to message #36509] Sat, 18 May 2002 12:42 Go to previous messageGo to previous message
Here are the relevant mounting dimensions:
Mounting Information Overall Diameter 15.15", 384.8mm
Baffle Hole Diameter 13.77", 349.6mm
Front Sealing Gasket fitted as standard
Rear Sealing Gasket fitted as standard
Mounting Holes Diameter 0.25", 6.4mm
Mounting Hole B.C.D. 14.56", 369.9mm
Depth 6.05", 153.6mm
Shipping Weight 14.6 lbs, 6.6 kg
Previous Topic: LOOKING FOR A 2way Crossover
Next Topic: question about applying veneer
Current Time: Sun Oct 25 08:24:41 CDT 2026
