Home » Sponsored » Pi Speakers » Horn lens causing 1k bump?
Re: Maybe the horn? Microphone? Measurement environment? Could be lots of things. [message #36486 is a reply to message #36477] Fri, 17 May 2002 08:59 Go to previous messageGo to previous message
RyanH is currently offline  RyanH
I'll try and take some measurements outside and use 3 different mics. I'll also mount it in the box (when done) and take some measurements. Unfortunately I don't have any other flares I can test with, but I will measure some other speakers with a published curve (non horn, I have some 7" Stryke fiberglass cone woofers) and see if there is a hump there also. Thanks for the info on all the different variables and I'll try and minimize all of them.
--Ryan
Previous Topic: 4Pi WIDTH, ROOM BOOST AND PORT PLACEMENT?
Next Topic: I lost my screws! (out of my compression drivers....)
Current Time: Thu Nov 19 11:22:17 CST 2026
