Home » Sponsored » Pi Speakers » What are the effects of cabinet volume on sensitivity??
Thanks Sam!! [message #36484 is a reply to message #36480] Fri, 17 May 2002 06:30 Go to previous message
Robert Hamel is currently offline  Robert Hamel
I know what you mean about the bass response. You are correct from 250hz and below. I have one very good position in my room I use for measurements. I have an idea from prevoius measurements on other speakers what the room is doing but like you said they are references and not absolutes. I always use another speaker as a reference tool from the same position in the room. I just swap them out to make the measurements. The driver spec. sheet calls it 98 and 2 give you 100db in the 4638??? So there are 3 diferent apparent ratings for the same driver?? We have 97 +3 in the 4638, 98 0n the driver sheet and 99 in the 3677. What I am getting appears flat just below what I expected. You are right if it sounds good "Don't worry about it"
Just trying to understand what is happening.
Thanks for your help.
Previous Topic: Thermionic 3 vs. Theatre 4
Next Topic: JBL 2225's available (not mine)
Current Time: Sat Nov 28 19:03:06 CST 2026
