Home » Sponsored » Pi Speakers » What are the effects of cabinet volume on sensitivity??
Good point they are relative to other speakers. [message #36473 is a reply to message #36463] Thu, 16 May 2002 20:09 Go to previous messageGo to previous message
Robert Hamel is currently offline  Robert Hamel
What I did was use an 87Db speaker as a reference with pink noise and then compared the level to the home builts which were 6db hotter. I used a speaker of higher sensitivity rated at 100db and it was 4db hotter so you are correct that the absolute is not right. 93 from the lower measuremant and 96 from the higher. That comes out to a 3db error between measurements. I am at 95 which gets me within a 3DB window if I split the two. You are good!!! I did not look at it that way before.
Thanks for your help.
Previous Topic: Thermionic 3 vs. Theatre 4
Next Topic: JBL 2225's available (not mine)
Current Time: Sat Nov 28 19:03:14 CST 2026
