Home » Sponsored » Pi Speakers » What are the effects of cabinet volume on sensitivity??
Measurement tolerance [message #36463 is a reply to message #36461] Thu, 16 May 2002 15:50 Go to previous messageGo to previous message
How and where did you measure these? Was it done in half-space outdoors, maybe on the ground pointed up? What measuring system did you use? I ask all these things, because there are a lot of places for ambiguity to creep in. If measured indoors, you can expect 6dB difference in average output just from moving speakers around in the room. I suggest a fairly good amount of tolerance should be considered if consistent references and calibrations aren't in place.
Previous Topic: Thermionic 3 vs. Theatre 4
Next Topic: JBL 2225's available (not mine)
Current Time: Sat Nov 28 19:03:20 CST 2026
