Home » Sponsored » Pi Speakers » what tools are required?
Re: Tools are Off Budget. [message #36418 is a reply to message #36416] Mon, 13 May 2002 17:02 Go to previous messageGo to previous message
LOL... Not bad fine print.
I built my Pi's with a hammer, a jig saw, a chop saw (most convenient thing since our table saw sucks) a drill with drill bits and and screw bits as well... A screwdriver, a rip file, and a couple other tools I think.
I had home depot cut most of the wood on their panel saw. I HIGHLY recommend doing this, as the saw tends to be very accurate and you can return the wood if the cuts are bad. You can also get even a lot of cuts cheap if you are a nice and patient person, in most cases anyway.
It'd be silly to not use a 10,000 dollar panel saw instead of a 400 dollar table saw...
Anyway, that was my main list of tools, although I haven't finished them all up quite yet.
Adam
Previous Topic: Cross Over layout
Next Topic: adding a midrange to the pi speakers
Current Time: Sat Nov 07 07:34:02 CST 2026
