Home » Sponsored » Pi Speakers » what tools are required?
Re: what tools are required? [message #36414 is a reply to message #36406] Mon, 13 May 2002 10:32 Go to previous messageGo to previous message
I'm going to let the resident woodworkers here answer that one because they know much more about woodworking than I do. One suggestion that may be of interest - You can cut the wood yourself but you might check the lumber yards and hardware stores to see if any are willing to cut the panels for you.
When I fill an order for completed speakers, I have the cabinets built by professional cabinetmakers and I take delivery of the cabinets and install the components in them. I can tell you that you'll only need a screwdriver to mount the drivers and crossovers into the cabinets, some white glue to attach the R13 insulation to the inside bottom, back and side nearest the port. You won't need a soldering iron or anything like that because the crossovers and cable assemblies are finished and ready for you to connect. You just press 'em on.
Previous Topic: Cross Over layout
Next Topic: adding a midrange to the pi speakers
Current Time: Sat Nov 07 07:33:58 CST 2026
