Home » Sponsored » Pi Speakers » Wayne, check this out...
Re: Wayne, check this out... [message #36331 is a reply to message #36325] Tue, 07 May 2002 21:06 Go to previous messageGo to previous message
Look at the JBL 2012 and the Eminence Delta 10. They're 10 inch drivers, not 8 inch, but I don't suspect that matters to you. I think you'll find they will serve you well for horn loaded midrange drivers. A three-way speaker is essentially a decade-split system, where each subsystem must cover a decade. A decade is about the bandwidth limit of a horn, so a three-way split can be a nice solution.
Two-way speakers require five octaves from each subsystem, and their main advantage is that of simplicity. There is only one crossover point, so there is only one place to consider the effects of overlap. This option is made possible since most speaker motors cover five octaves adequately. However, no horns have this kind of bandwidth, so horn loading can only benefit a part of system response. Compensation must be used if horn are employed over three octaves, so it is a "must" in horn-loaded two-way speakers.
Previous Topic: L-pad calculator
Next Topic: Built-in bass for Oris horns in dedicated sound room
Current Time: Fri Nov 06 21:00:25 CST 2026
