Home » Sponsored » Pi Speakers » Wayne, check this out...
Re: Wayne, check this out... [message #36323 is a reply to message #36322] Tue, 07 May 2002 15:42 Go to previous messageGo to previous message
Have you tried the JBL 2446 or 2450 2" exit compression drivers? They are much more expensive, but much more high quality too. And then there's the TAD 4001.
Alternately, consider running a cone driver midrange. You can horn load them and crossover to 1" compression drivers, which perform much better at high frequency than the larger drivers with 2" throats.
Previous Topic: L-pad calculator
Next Topic: Built-in bass for Oris horns in dedicated sound room
Current Time: Fri Nov 06 21:00:53 CST 2026
