Home » Sponsored » Pi Speakers » Wayne, check this out...
Re: Wayne, check this out... [message #36321 is a reply to message #36320] Tue, 07 May 2002 11:29 Go to previous messageGo to previous message
I prefer to use 1" compression horns in two-way systems, because 2" exit devices don't have the top octave performance. They're just too big. Compensation helps a lot though.
If you order a PSD3003 from Eminence right now, you'll find they're not in stock. Anything else will be at your door in days, but the PSD3003 and its diaphragms aren't available. I suspect they are preparing to supercede it with a replacement.
Previous Topic: L-pad calculator
Next Topic: Built-in bass for Oris horns in dedicated sound room
Current Time: Fri Nov 06 21:01:18 CST 2026
