Home » Sponsored » Pi Speakers » Ten Pi Info
Re: Ten Pi Info [message #36289 is a reply to message #36288] Sun, 05 May 2002 12:06 Go to previous messageGo to previous message
I don't know how anybody else built theirs, but I ran into the same problem you did. My solution was to extend the port out from the baffle a little.
Just so you know, I used Kappa 15lf's in my pair as well, and I'm quite happy with them. A bit of midbass boominess, however that likely has more to do with the bracing situation rather than the driver itself.
I don't recall the exact alignment I used anymore, but it was something like 2.2 cubic feet (after displacement) with a 4"x10" port, with around a pound of polyfill in the chamber.
Adam
Previous Topic: need to find a complete selection of drivers
Next Topic: Using a JBL 2405 w/2" compression driver.
Current Time: Sat Oct 24 00:23:16 CDT 2026
