Home » Sponsored » Pi Speakers » Pi designed bass for Oris horns?
Re: Pi designed bass for Oris horns? [message #36277 is a reply to message #36264] Sat, 04 May 2002 19:43 Go to previous messageGo to previous message
I'd start by positioning the speakers in the corners, with the mid/high horns facing in at 45 degrees so that their pattern was within the wall angle. This allows the bass to operate in eighth-space, but doesn't introduce early reflections at higher frequencies because the mid/high horn pattern is within the wall angle. Keep the path length distance between sound sources under 1/4 wavelength at the crossover point. So for crossover around 200Hz, that's about a foot and a half.
Previous Topic: 10pi + fronthorn
Next Topic: My Oris/10Pi system
Current Time: Mon Nov 02 07:27:26 CST 2026
