Home » Sponsored » Pi Speakers » Top octave compensation on non Eminence comp drivers
Re: Top octave compensation on non Eminence comp drivers [message #36111 is a reply to message #36108] Fri, 26 April 2002 15:00 Go to previous messageGo to previous message
Depending on the horn lense you'll be using, you will likely still need compensation.
Bi-radial lenses like the CH-3 will attenuate the top end of the compression driver's response, so compensation wouldn't hurt. However, I don't think you will need as much with that compression driver. Wayne's compensation circuit takes into account the natural rolloff of the PSD2002's as well as flare modification.
If I remember correctly, the Selenium compression drivers all go down to 1,000 Hz or so (agian, if I remember right) I would urge you to try taking it that low. If not, a 2nd order LP at 1.5 kHz with impedance compensation will handle the peaking adequately, coming from a guy who has owned a total of eight K15lfa's.
Adam
Previous Topic: Oops.. too big!
Next Topic: bmar, please see this post about my Basie
Current Time: Tue Oct 20 14:53:14 CDT 2026
