Home » Sponsored » Pi Speakers » Filling screw holes for Veneer
Re: Filling screw holes for Veneer (Quick filler) [message #36093 is a reply to message #36071] Tue, 23 April 2002 20:02 Go to previous messageGo to previous message
newjerseybt is currently offline  newjerseybt
In a pinch you can mix fine saw dust (from belt sander) with Elmers
furniture glue. This will not look pretty and will not stain. I am
assuming you will veneer over the screws. Fill over the holes 1/16
of an inch as the mix will shrink when dry. Use a sanding block with 60 grit to level the filler.
Previous Topic: good plywood? bad plywood? I'm the plywood with the gun.
Next Topic: Madman Wayne, these kit prices are a freakin' steal!
Current Time: Thu Nov 05 22:40:46 CST 2026
