Home » Sponsored » Pi Speakers » compression driver + 15 inch or large piezo horn + 15 inch
Re: compression driver + 15 inch or large piezo horn + 15 inch [message #36091 is a reply to message #36082] Tue, 23 April 2002 18:06 Go to previous message
mhammill is currently offline  mhammill
The ksn1188 piezo does go down to 700hz and is remarkably smooth with a 5x15 parts express horn but the efficiency is no match for a delta15. It's about 93db and a delta15 is more like 100db so it just won't keep up. But there are other 15" woofers that would work very well with this horn.
But no match for a theater 4pi.
Good luck.
Mike H.
Previous Topic: Theater series Four Pi
Next Topic: initial exponential horn design
Current Time: Wed Oct 14 21:48:27 CDT 2026
