Home » Sponsored » Pi Speakers » compression driver + 15 inch or large piezo horn + 15 inch
Re: compression driver + 15 inch or large piezo horn + 15 inch [message #36084 is a reply to message #36082] Tue, 23 April 2002 15:49 Go to previous messageGo to previous message
Personally, I'd totally go with the compression driver.
Even larger sized piezos may only go down to 2 or 3 kHz with authority. This frequency is too high for a 15" woofer to run up to effectively. Go for the compression driver.
As far as the ports go, well how many 'ways' a system has has nothing to do with ports. A 2-way system simply means that the frequency band is split into two portions, each diverted to different speakers. So a 2-way system would have a woofer and a tweeter. A three way system would have a woofer, midrange and tweeter. Etc.
Adam
Previous Topic: Theater series Four Pi
Next Topic: initial exponential horn design
Current Time: Thu Nov 05 19:43:53 CST 2026
