Home » Sponsored » Pi Speakers » Cabinet Help
Re: Another point to wory about. [message #36049 is a reply to message #36044] Sat, 20 April 2002 15:17 Go to previous message
A few simple ways that you could do it would be
to use fineered ply for the sides and have that come up to a 25mm square solid wood for the corners.
use fineer ply and glue an edge fineer on all edges before assembling
and finally, just fineer the whole box after you build it from MDF.
there are lots of ways. none are better than the other. do what is easy for you and also what you have tools to use.
ciao
Previous Topic: Three way speakers.
Next Topic: Personal DIY Loudspeaker web sites list
Current Time: Wed Nov 04 09:04:02 CST 2026
