Home » Sponsored » Pi Speakers » 14ga solid copper wire? (for Wayne)
Speaker cable and wire properties, revisited [message #36035 is a reply to message #36033] Thu, 18 April 2002 19:22 Go to previous messageGo to previous message
Actually, I said the larger solid core wire would be fine. Please revisit the post called "Speaker cable and wire properties".
Since audio frequencies are low, you will not have the skin effect to be concerned with, and that's the main reason to use stranded wires. The main thing in this application is resistance, so large solid wire is acceptable. However, it is much easier to use stranded wire because it is more flexible, so that and its superiority at higher frequencies makes large stranded pure-copper cable the best option.
Previous Topic: attenuating 1197 piezo
Next Topic: People using Paramours...
Current Time: Thu Nov 05 00:44:32 CST 2026
