Home » Sponsored » Pi Speakers » crossover design... help....
crossover design... help.... [message #35968] Mon, 15 April 2002 06:46 Go to previous message
Pilkar is currently offline  Pilkar
hi Wayne,
i`m building a 2 way speaker (conventional bass reflex) and i want to build the crossovers myself... i will use this two drivers: Selenium WPU1205 and Selenium D405Ti on a Selenium HL14-50 horn... which data should i look for building the crossover? i plan to cross them at 2k2 with a 12dB/oct. slope... how can i know if i need a compensation network or the damper or both? i read the doc file that explains how to do it... but it is a little difficult for me to understand everything... do you have a simple way to calculate the crossover and compensation network components? i will build a 40 liter box and will be tuned to 55Hz... can you help me?
thank you very much
Matias
Previous Topic: Horn flare survey
Next Topic: Folded horn subs--yuck!
Current Time: Sat Nov 28 21:29:59 CST 2026
