Home » Sponsored » Pi Speakers » Horn flare survey
Re: Horn flare survey [message #35948 is a reply to message #35941] Fri, 12 April 2002 19:10 Go to previous messageGo to previous message
I hate the soft plastic of the CH-3; but it looks better on the Theatre without a doubt.
OTOH, it should be easy enough to simulate recessing the 290 with a molding thereby extending it's apparent size.
Make the front baffle three piece: inner 24X36 to mount the horn, mid also 24X36 with a slot cut beyond the outer dimension of the horn far enough to accomodate 3/4 round trim to flare the baffle and finally the 24X ? for whichever manner you choose to recess the woofer.
Any takers?
Previous Topic: Wayne, what about the compensation network??
Next Topic: crossover design... help....
Current Time: Sat Nov 28 21:21:30 CST 2026
