Home » Sponsored » Pi Speakers » Active highpass filter
Re: Active highpass filter [message #35915 is a reply to message #35908] Wed, 10 April 2002 19:04 Go to previous messageGo to previous message
Below you'll find a rough draft design I made of an active crossover for bi-amp applications. It needs a section for the high-pass "rumble filter" as you've described added to the LF section. And it might be nice to add another jumper-selectable section to both the LF and HF sections that provides a 6dB/octave filter. With a single 6dB/octave jumper-selectable stage and a pair of jumper-selectable 12dB/octave stages, the user can configure 6dB, 12dB, 18dB, 24dB and 30dB per octave stages or 1st through 5th order filters. The rumble filter should be made having a fixed high-order slope, but should have its frequency configurable. In spite of the lack of these things, the schematic shows the circuit for a suitable active crossover.
Active Bi-Amp Crossover
You can make 'em on breadboards as Greg did. Maybe later I'll continue to research this, do a full analysis, make an improved schematic with specific component values and have circuit boards etched in quantity so that I can offer DIY kits and fully assembled units.
Previous Topic: Need advice...and plans
Next Topic: Theater 4 Pi one channel complete
Current Time: Tue Oct 20 19:08:26 CDT 2026
