Home » Sponsored » Pi Speakers » L-pad on LF driver
Re: L-pad on LF driver [message #35875 is a reply to message #35866] Mon, 08 April 2002 15:21 Go to previous messageGo to previous message
freddyi is currently offline  freddyi
Hi Tom
not my fave scenario but had to do it on my Edgarhorn 100 system to match midhorn - the 1/4 size 100Hz m=0.5 horn uses a JBL 2220H so above ~125Hz, sensitiviy is about 109dB 1W/1M - midhorn probababy 103 ss - JBL LE5 on 250Hz rectangular tractrix - bottom augmented by 1-1/8 size 40hz Monolith
in this situation impedance fluctuation is pretty benign so I got nice results running everyting including 'sub' with homemade parallel 2A3SE amp and similar-better results with mod Eito ST70 running 6BX7 ppp (Eico has bit higher damping factor - probably ~4)
no need for expensive resistors - modern sandcast have little inductance.
have you already built the horn? - does it have a small back chamber? what flare, etc? - will assume woofer with 103 rating is low qes (?)
Freddy
Previous Topic: Review of speakers?
Next Topic: would like plans...
Current Time: Tue Oct 20 12:37:52 CDT 2026
