Home » Sponsored » Pi Speakers » Port air speed.
try to avoid operation below Fs [message #35803 is a reply to message #35802] Thu, 04 April 2002 12:09 Go to previous messageGo to previous message
as distortion will be increasing rapidly. To determine actual system Fb with a certain enclosure/port configuration, measure the frequency of the lower and upper z peaks. Those are Fl and Fh. Now seal the port, and determine Fc, the single z peak. Fb = sq.rt. (Fl^2 + Fh^2 - Fc^2) Should be about where the dip was between the peaks when vented. Box plot advises keeping BELOW MACH 0.2 with your port velocity...if too high, as you noted, it can be audible under some conditions...Sam
Previous Topic: Tweeter questions
Next Topic: Musical Fidelity MC-2
Current Time: Thu Nov 05 18:10:57 CST 2026
