Home » Sponsored » Pi Speakers » minimum width of cabinet on Three Pi reflex
effect of 'glass on box volume [message #35800 is a reply to message #35783] Thu, 04 April 2002 05:49 Go to previous messageGo to previous message
is very hard, maybe not even possible to predict. I do know that my 4 Pi Pro's are very close to a net internal Vb of 2.5cu.ft., and when verifying Fb with specific port tube configurations...the only answer explaining the resultant Fb's is that THE BOX THINKS IT'S ABOUT 3.3cu.ft.. At 40 and the final 48Hz. Fb, boxplot agrees with my Fb/port tube measurement results only when the box is specified to be around 3.3cu.ft.
So in this ONE SPECIFIC case, a 2.5cu.ft. volume, PLUS 1.2cu.ft. of R13, resulted in an effective Vb of around 3.3cu.ft. Verified twice by careful zplots at 40 and 48Hz. (using 3in. and 1.5in. port tube lengths). A conservative estimate is the "apparent" volume WAS INCREASED by at least half the amount of 'glass added. The major implication of the added volume is that if not accounted for, your Vb will be too large, causing system tuning to be lower than desired...maybe causing low end extension of the bass to suffer. 5 or 10Hz. of box tuning can be significant...if you can trust the sim data. JBL2035 was used in the situation above. Sam
Previous Topic: Quick question
Next Topic: Erik from Holland - do you play in band?
Current Time: Fri Nov 06 00:44:21 CST 2026
