Home » Sponsored » Pi Speakers » minimum width of cabinet on Three Pi reflex
Re: two "walls" will be almost touching the driver [message #35783 is a reply to message #35769] Wed, 03 April 2002 16:31 Go to previous messageGo to previous message
Hodel is currently offline  Hodel
Sam,
Thanks for the help...it sounds like I need to make sure I have enough room on the sides for the damping material. Could you recomment anything other than fiberglass (like bubble pack?). Do I increase the volume of the enclousure by the volume of the fiberglass/bubblepack or is it transparent to sound? I will use the same volume as Wayne suggest for the Thermionics Three Pi reflex which is about 4 cubic feet.
Previous Topic: Quick question
Next Topic: Erik from Holland - do you play in band?
Current Time: Sat Nov 07 01:09:59 CST 2026
