Home » Sponsored » Pi Speakers » Ratings of horns?
Re: Ratings of horns? [message #35781 is a reply to message #35780] Wed, 03 April 2002 15:28 Go to previous messageGo to previous message
Horns are often described by their flare rate. Assuming the horn is a standard Salmon shape or Tractrix, not a hybrid, if you know the type of horn (exponential, tractrix, conical), then the flare rate describes the horn profile. The mouth must have sufficient area to support the flare rate or response will be peaky. But if these conditions are met, then the flare rate essentially sets the lower cutoff. For a tractrix horn, the lower -3dB point is about a half octave above its flare rate. Exponential horns generally work down to their flare frequency. Horns have bandwidth of about three octaves. So its upper cutoff is about three octave above its lower cutoff.
Previous Topic: 4 Pi Pro's and pp6BQ5's
Next Topic: A link for the tube people
Current Time: Fri Nov 06 00:52:38 CST 2026
