Home » Sponsored » Pi Speakers » minimum width of cabinet on Three Pi reflex
two "walls" will be almost touching the driver [message #35769 is a reply to message #35766] Wed, 03 April 2002 05:55 Go to previous messageGo to previous message
and may not permit you to place sufficient damping material inside. Sound energy from the rear of the cone will be more able to bounce right back thru the cone instead of being absorbed, often complained of as "too forward a midrange" and/or peakiness. Instead of the dimensional ratio's used by Wayne, you could try Weem's suggestion (0.67/1.0/1.8) for a tall, narrow box. How many cu.ft. do you want/need? Sam
put a layer of R13 'glass at each end (top/bottom) of the long enclosure to help reduce/suppress standing wave generation...
orient the driver to insure that the solid portions of the basket are towards the walls if possible...
Previous Topic: Quick question
Next Topic: Erik from Holland - do you play in band?
Current Time: Tue Oct 06 06:22:58 CDT 2026
