Home » Sponsored » Pi Speakers » kewpee burgers & never enough beer
Re: Four hours of sleep. [message #35747 is a reply to message #35738] Sun, 31 March 2002 17:09 Go to previous messageGo to previous message
hi kevin, that's more sleep than i got. regarding the x-over you can use a stock eminence pxb116 with compensation on the tweeter output ( that's what you heard at the show). on the positive wire going from the output of the x-over to the horn driver you insert a .47mf cap in parallel with a 47ohm 10w resistor. i think i paid 3 bucks for the parts. that's it. wayne also has custom x-overs available. the amp i used was a 25 watt per channel kr 18 with 300bxls output tubes. at home i use a rane ac22 electronic x-over with a 100 watt sand amp and a 15 watt tube amp. i've now got the extra power and the sweetness of the tubes. good luck on your project!
cheers,
george
Previous Topic: Wow... great work Wayne.
Next Topic: Midwest Audiofest
Current Time: Sun Oct 25 18:18:22 CDT 2026
