Home » Sponsored » Pi Speakers » Wayne, did you get my re-mail???
Yes, I got your mail; Sent a reply too [message #35721 is a reply to message #35719] Thu, 28 March 2002 09:27 Go to previous message
Yes, I sent you a reply. Check your mail; I've sent plans for Theater Series four π speakers.
Please note that this design uses the Eminence Delta 15 woofer/midrange and not the Kappa 15LF. As I mentioned in my first reply to you, I do not have plans drawn for a speaker containing a Kappa series driver. If you want to use a Kappa 15LF woofer, you may find that a different box and port is better suited. You should also examine the response curve and consider whether the drivers you've chosen are suitable for a two-way design. Many of the large-format Eminence woofers are, but I find that the LF-suffixed parts sometimes aren't. After finding a suitable woofer/midrange, I would design the speaker cabinet with PiAlign and model it with BoxPlot to confirm the design and see its response curve.
Previous Topic: I got my horns today, Wow! these speakers rock!!
Next Topic: My new speakers arrived today
Current Time: Mon Nov 02 15:03:10 CST 2026
