Home » Sponsored » Pi Speakers » Eminance horn bolts
Re: Eminance horn bolts [message #35610 is a reply to message #35580] Wed, 20 March 2002 20:00 Go to previous message
Super_BQ is currently offline  Super_BQ
You can take a look at the photo below what i've done to fit the bolt:
The local fastener shop had a hard time identifying the alen key bolt to fit in. On the invoice the description of the bolt is "Socket Cap Screw - 6 x 16". So i assume 6mm head x 16mm long for the inside 3 bolts. $1.35NZ each so (60 cents US each).
Previous Topic: no promises but i'm try to snag one of these tube
Next Topic: More four π photo's
Current Time: Tue Nov 03 05:42:13 CST 2026
