Home » Sponsored » Pi Speakers » Sub placement
Re: Sub placement [message #35539 is a reply to message #35535] Mon, 18 March 2002 09:05 Go to previous messageGo to previous message
Robert Hamel is currently offline  Robert Hamel
Hello
That's a tuff one. If you are limited with placement its a real crap shoot if the placement will be good or not. How are you 4Pi's placed and are the sub woofer placements in the same plane along the same wall??? How low are you crossing over?
You should crossover as low as possible. If the sub and mains are on the same wall then it should be much harder to hear the sub provided you cross low enough.
Can you have a friend lend you a sub to get an idea about the placement. If it's a bad spot in the room it won't matter what you put it there so that might save you some time and heart ache. Get yourself a good set-up CD that has sweeps for sub integration and borrow an SPL metter if you can. If you can get your friends or a dealer loaner to integrate well you should be fine.
Good Luck
Previous Topic: Might actually get to build 10 Pi's this summer!
Next Topic: Reflex loaded w bins
Current Time: Mon Nov 23 10:17:35 CST 2026
