Home » Sponsored » Pi Speakers » Sub placement
Re: Sub placement [message #35536 is a reply to message #35535] Sun, 17 March 2002 13:57 Go to previous messageGo to previous message
Sub placement is *extremely* important.
I have had some quite incredible subs through my room (in both sound quality and quantity) and with poor placement, it simply doesn't matter. You can get weak, nonexsistant, sloppy bass out of even the best of subs if you don't place them right.
I can't tell you how they will integrate with your 4 pi's because I don't know what your room setup is like. It depends on corner or wall placement, the location of the sub and the location of the listener.
The best way to do it is to place the sub in the spot where you will be listening from, and walk around the room until you find a spot where the bass sounds the best. Then put your sub there.
All depends on your room.
Adam
Previous Topic: Might actually get to build 10 Pi's this summer!
Next Topic: Reflex loaded w bins
Current Time: Mon Nov 23 10:17:34 CST 2026
