Home » Sponsored » Pi Speakers » What are you're views on re-coning,re-foaming
What are you're views on re-coning,re-foaming [message #35409] Sun, 10 March 2002 07:05 Go to previous message
Rudi is currently offline  Rudi
When A loudspeaker driver cost at least a hundred pounds or more,
instead of throwning the driver away and get a new one; you can have it re-coned.Which costs less than buying a new one. Using the same magnet,frame,terminals.
Just replacing the cone,dustcap,surround,voice coil,voice coil former,dampener. And sometimes re-magnetising the magnet,if the voice coil has de-magnetsied it when it blew.
Re-foaming or re-rubbering a speaker.Can be done to old vintage or
any old speaker where the foam has rotted,only if this is just the problem and it's worth the hassle and money.
So example,you can re-foam an old vintage speaker which is rare to get hold of,and costs you much less than buying another new loudspeaker of the actual specs the damaged on had.
Previous Topic: Wayne, suggestions for Pi rears/ nearfield monitors.
Next Topic: pushed in tweeter
Current Time: Sat Nov 28 19:53:37 CST 2026
