Home » Sponsored » Pi Speakers » Questions on dual 2226 woofer cabinets
Re: Use an 600-800Hz crossover on the 2446 [message #35314 is a reply to message #35310] Mon, 04 March 2002 22:56 Go to previous messageGo to previous message
If you plan to use two woofers, I'd run it as a 2.5-way, with just a large coil on the lower woofer to limit its output to bass only. The upper woofer would be a midwoofer, and it should be connected using the π crossover. Be sure to use a Zobel on the midwoofer to prevent peaking near the crossover frequency.
Previous Topic: Types of distortion to avoid
Next Topic: Will Pi Come Up with a "Tower" Enclosure?
Current Time: Thu Nov 05 22:52:53 CST 2026
