Home » Sponsored » Pi Speakers » crossover component burn-in:)
screwed by geometry, [message #35263 is a reply to message #35262] Thu, 28 February 2002 06:40 Go to previous message
After drawing a side view of my mike and driver positions, it seems the dip is really a diffraction/cancellation situation. The mike was about 39 inches high - halfway between the centerline of the 511 and the UPPER woof, which made the path length from each of the two woofs to the mike differ by approx. 7 inches, one-half wavelength at 960 Hz. So it was science, not room ghosts or coil values that were at play after all. Probably would not have been there at a different distance/height...also, above 500 Hz, as the dispersion of the lower woof was narrowing, less energy would have reached the mike that was about 30 degrees away from the lower woofs axis. Sand, sand, sand...
Previous Topic: Making sure before I buy
Next Topic: Pi 2's with Bottlehead Paramour Review
Current Time: Thu Nov 26 11:56:51 CST 2026
