Home » Sponsored » Pi Speakers » crossover component burn-in:)
1.0 mH too much choke for dual 2226J's? [message #35247 is a reply to message #35244] Wed, 27 February 2002 09:04 Go to previous messageGo to previous message
Wayne, some interesting raw in room data, taken on axis at 1 meter, rat meter on tripod, using the temporary coils/xovers.
30 Hz. -16 dB
33 -10
36 - 6
40 - 9
50 - 8
60 - 1.5
70 - 4
80 - 1.5
90 0 dbmo
100 0
200 - 2
300 - 1
400 0
500 - 4
600 - 6
700 - 8
800 - 8
900 - 7
1000 -10
1600 - 1
2k - 2
3k + 1
4k + 1.5
5k + 2
6k + 3
7k 0
8k - 3
9k + 1
10k - 2
11k - 2
12k - 4
13k - 5
14k -10
15k - 9
16k - 6
17k -10
18k - 4
19k +10
20k - 4
The 1.0 mH is giving too much attenuation to the DUAL 2226J's, but should be close to what the 2035's will need. The depressed levels between 500 Hz. and 1k were not present without the xover, in prior testing. The 4648A-8's were flat to 1k before...need to swap in 0.8 mH soon. But here's an "honest" in room F10 of 33 Hz. anyway.
From 1.6 kHz. to 11k, pretty happy here. And when measured before, these 35480 alum. diaphrams did not have the top end extension of 34647's I also use, so the drop after there is expected. And up high, the rat meter readings are supposed to be "corrected" for accuracy. This is raw, unmanipulated, in room, whatever.
After 10k, Pepper got pissed off and started barking...hard on the little needle!!! That's what closets are for :)
Driver fore/aft alignment initially was with the HF acoustic center 4.25 inches BEHIND the LF...the drivers relative positions were then slightly adjusted to eliminate any phase difference in the drivers outputs at 1.6 kHz...Sam
Previous Topic: Making sure before I buy
Next Topic: Pi 2's with Bottlehead Paramour Review
Current Time: Thu Nov 26 11:57:30 CST 2026
