Home » Sponsored » Pi Speakers » Wayne-Alpha/Delta ksn1188 eff match
Re: Wayne-Alpha/Delta ksn1188 eff match [message #35168 is a reply to message #35166] Wed, 20 February 2002 12:51 Go to previous message
The electro-mechanical parameters of the Alpha and Delta drivers is different but the average broadband efficiency is nearly the same. There is a slight padding difference between models, but not very much. The peaks up high are due to breakup modes and you should crossover lower than that. If you'll crossover below 2kHz, you will not have the peaks from breakup modes.
Previous Topic: Crossovers on onePi and twoPi?
Next Topic: JBL SCOOPS>>>
Current Time: Thu Nov 05 21:49:32 CST 2026
